G-Code, CAD, and CAM => LazyCam (Beta) => Topic started by: jlautomatio on October 04, 2006, 10:01:11 AM
need info on new upload
my problem is when i generate g code with lazycam it generate like this
c:\mach3\gcodef09.nc
it should be
c:\mach3\gcode\f09.nc
Okay that will be done next week after i get back from the trip :)
hi find some think it look like if i generate the gcode and change the directory it mist the \
thank you
hi brian
soon you fix the problem let me know and put on ftp
thank you
jacques
allo brian
not fiend the problem on lazycam
thank you
jacques
There is work being done on it now :)
Don't know what to tell you.. I can get it to break ???
Could you post the file and your XML?
Brian
this 2 file the original and after
the original it ok save at c:\mach3\gcode\
and after i change dir like C:\mach3\gcode\demo
it mist the \ after demo and save like this c:\mach3\gcode demof34.nc
so the file is demof34.nc it should be in file c:\mach3\gcode\demo\ and name f34.nc
you gone to find in the xml file after place to save it mist the \ after c:\mach3\gcode\demo <-----------
thank you
Jacques
sory this is the one after i change dir
thank you
jacques
hello
still not find the problem about the \ missing
thank you
jacques
I will test it in the next few days now that I have your XML
Brian
allo Brian
on lazcam 2.66 still missing the \ when we change in gcode file options it lose the \
thank you
I have tested for that and I can't get it to post wrong :( there is something that we are missing and at some point it is going to show up!
Any one have this happen?
Hi, Jlautomatio & Brian
If Mach3 & LC reside in other than Mach3 folder, like Mach3R2.0.010.
The Gcode post's to Mach3R2.0.010\ gcodetest55Dotpolyline.tap, rather than Mach3R2.0.010\gcode\test55Dotpolyline.tap.
Need's a back-slash gcode " \" test55Dotpolyline.tap is missing.
Thank's Chip
Okay that is two of you with the same problem :( I still can't get it to happen here! That makes it very hard to fix... I think that I will have to recode that section and see if i fix it by luck..
this is small video to see the problem
hi Brian
on ver 2.66 you change------------ layer control---------------- for ------------auto clean setting -------------------?????
how we put all the inf we use to put on layer control it was easy on the first one
thank you jacques
you can change the settings at the bottom of the screen :) There should be a video showing how to do this...
Take a look at the video and if you have any problems or questions I am here
thanks
Brian
