Hello Guest it is November 13, 2026, 05:53:17 PM
Author Topic: How to display DRO's on LCD with Pokeys55  (Read 45315 times)
« on: March 23, 2010, 02:52:20 PM »
Hello everybody,
I bought a Pokeys55 for building up a pendant.
The LCD works very well with the Pokeys-Software, but now I was searching how to get the LCD running with Mach3 but I didn't find anything helpful for Newbies like me.
It is a 4x20 LCD and I want to display the DRO-Values for X,Y,Z and A (Maybe later I can display Spindle Speed and Feedrate as well?).
Can somebody give me a hint, how to do this with a VB macro? I read something about Userlabels.
How do I get the DRO-Values in these Userlabels so I can display them?
I've never written VB macros before.
Thank you so much in advance and sorry for my English :)
Greetings,
Robert (Germany)
Offline borisz
  •  220 220
    • www.poscope.com
Re: How to display DRO's on LCD with Pokeys55
« Reply #1 on: March 23, 2010, 03:33:09 PM »
Hi!
Did you checked PoKeys plugin for Mach which can be downloaded from www.poscope.com?
It has direct LCD support without programing..
regards
Boris
www.poscope.com home of PoKeys USB HID, IO, USB, Ethernet controler and PoScope USB PC oscilloscope
« Reply #2 on: March 23, 2010, 03:46:09 PM »
Hi Boris,
yes, I mean this plugin.
But I don't find out how to get my DRO Values on my LCD. Is there a How2 anywhere?
Robert
Offline borisz
  •  220 220
    • www.poscope.com
« Reply #3 on: March 23, 2010, 04:48:08 PM »
OH, I have unreleased beta.
Will ask Scott if he is close to release.
regards
Boris
« Reply #4 on: March 24, 2010, 03:28:51 AM »
the current pokeys 7.4 that is on boris/s site, is LCD capable, please see the HELP button on the plugin dialog.
also, you will need to choose what labels to use for your DRO display, then send your DRO code to them via VB, see Wiki on how to use VB.
scott
« Reply #5 on: March 24, 2010, 05:26:51 AM »
Okay, thanks. So there is no easy way to do this without studying VB. I will try my best.
@Boris
Does the Plugin work only with LCD on the first pin configuration (23-26 and 28-30) ?
You mailed me, that I probably have found a bug in the latest pokeys firmware, so Pins 23-26 aren't working for LCD right now.
Do you know when this problem can be solved and when an update will be released?
Thank you,
regards,
Robert
Offline borisz
  •  220 220
    • www.poscope.com
« Reply #6 on: March 24, 2010, 05:37:02 AM »
LCD2 is working now. LCD1 should be solved in about 2-3 weeks.
regards
Boris
« Reply #7 on: March 24, 2010, 02:10:14 PM »
LCD2 is working now
Hi Boris,
you mean the Mach3 Pokeys Plugin? Is there an update that works with LCD2 as well?
In the 7.5 version from poscope.com the label in the config dialog says: "Use LCD Display (Pins 23-26, 28-30 used by LCD)"
What I made so far in the Pokeys Plugin config dialog:
And then I activated Macropump and made a file called macropump.m1s where I put this in:
So, the DRO values should be permanentally formatted and written into the userlabels, right?
But my LCD2 (pins 28-30, 31-34) displays nothing.
Shall I wait for the bugfix?
Thank you.
regards,
Robert
Offline borisz
  •  220 220
    • www.poscope.com
« Reply #8 on: March 24, 2010, 03:31:41 PM »
Please wait for bugfix. Also plugin with LCD2 support should be released soon.
regards
Boris
Offline eloid
  •  33 33
« Reply #9 on: April 16, 2010, 10:39:46 PM »
any updates for this?
regards
Boris
