Hello Guest it is November 13, 2026, 05:56:58 PM
Author Topic: Pokeys Disabled ?  (Read 60980 times)
Pokeys Disabled ?
« on: March 01, 2010, 05:15:03 AM »
When i have focus on the MDi line
The Pokeys is disabled "Spindle Button at least", is this fixable. ?
Phil
Offline borisz
  •  220 220
    • www.poscope.com
Re: Pokeys Disabled ?
« Reply #1 on: March 01, 2010, 05:28:42 AM »
Hi!
I am not very familiar with Mach (but I am using it). Please explain your problem more in details.
regards
Boris
« Reply #2 on: March 01, 2010, 08:35:44 AM »
Hi Boris
When this screen is being used and the MDI is active then the spindle button does not work
When the focus is removed then spindle button works OK
Phil
« Reply #3 on: March 01, 2010, 01:39:05 PM »
Are you talking about a physical button or the screen button? If a physical button how have you got it set up?
Offline borisz
  •  220 220
    • www.poscope.com
« Reply #4 on: March 01, 2010, 02:02:54 PM »
Phil!
Please provide us with detail information what you did and you want to do.
My crystal bowl is unfortunately on repair.  ;D
regards
Boris
« Reply #5 on: March 02, 2010, 04:04:32 AM »
Hood spindle has a Hotkey and that hotkey is mapped to a button in Pokeys
Phil!
regards
Boris
Boris no need for a crystal ball just read post number one "I want to press a button that is connected to Pokeys"
Also read number three this shows what i am doing while the Pokeys is disabled.
Due to the tone of your answer i must ask the question, Is this a bug in Pokeys
Phil
« Reply #6 on: March 02, 2010, 04:22:27 AM »
That is why its not working, cant have a hotkey getting used when in MDI Line ;)
Further to that hotkeys are not a good idea in my opinion, much better to use OEM Triggers as they will work at any time where hotkeys only work when there is the button on the screen at the time. For example if you have a MPG and want to change the axis that it jogs on you would need to have that button on the screen if using hotkeys, so that could involve changing to another page in the screenset. With an OEM you can do it at any time, even while in a wizard  ;)
« Last Edit: March 02, 2010, 04:25:35 AM by Hood »
Offline borisz
  •  220 220
    • www.poscope.com
« Reply #7 on: March 02, 2010, 04:26:45 AM »
 ;D Phill, no reported and leaving bugs in a PoKeys.
Crystal bowl was supposed to be a joke.
You should not be so misterious when you have a problem.
Hood was faster. Thanks Hood.
regards
Boris
« Reply #8 on: March 02, 2010, 04:51:33 AM »
Hood good helpful answer as always thanks
Boris you need some lessons in humour  ::)
Likewise my comment about bugs in Pokeys was also a joke.
Phil
« Reply #9 on: March 02, 2010, 11:27:54 AM »
OK learning as i go i have set up some keys to to use the oem triggers
When i did that to jogging letting go of the button did nothing for my heart rate as the machine continued jogging
I have the pokeys set as digital input and invert pin ticked
Phil
