Hello Guest it is September 26, 2026, 03:51:15 AM
Author Topic: cannot reverse run from present feedhold  (Read 35629 times)
Re: cannot reverse run from present feedhold
« Reply #10 on: February 25, 2010, 01:36:20 AM »
As I said above use the additional options button on the reply page and when you press choose you will be able to browse your drive to the correct xml and attach it.
If it is named wr-408 then it is likely that you wont need to rename unless someone else has posted a file with that exact name.
« Reply #11 on: February 25, 2010, 06:58:52 AM »
My brain finally clicked!
Thanks, Woodenbug
« Reply #12 on: February 25, 2010, 08:56:41 AM »
Will look at your xml when I get home, bit hectic at the workshop today.
« Reply #13 on: February 25, 2010, 09:11:22 AM »
Thanks! :)
« Reply #14 on: February 25, 2010, 01:56:35 PM »
Have a look on the diagnostics page, are the LEDs for the X axis limit and home switch on?
They are here but I have no idea why except that it has something to do with the port address of DF00
Double check that is the correct address for your port.
« Reply #15 on: February 25, 2010, 02:35:07 PM »
I checked the limit switch and it is good. The settings seem to be correct all the port is 1 and the pin is 11.
Woodenbug
« Reply #16 on: February 25, 2010, 02:39:06 PM »
Do you see the LED for M1-- Limit and M1 Home lit on the diagnostics page when the limit is not activated?
Do you see these LEDs change state when you activate the switch manually?
Is the parallel port that you are using an onboard port or a PCI card?
« Reply #17 on: February 25, 2010, 02:42:42 PM »
It is a pci card. Yes when I activated the switch last night they all went red.
« Reply #18 on: February 25, 2010, 02:47:35 PM »
Have a look in device manager at the port resources and check you have the correct address in.
If you can double check the LEDs on the diagnostics page as they should be yellow when activated, so if you see yellow for the two mentioned above when they are not activated it means something is wrong.
« Reply #19 on: February 25, 2010, 02:51:05 PM »
what should the address be?
Woodenbug
