Hello Guest it is November 10, 2026, 05:19:45 AM
Author Topic: cannot reverse run from present feedhold  (Read 36638 times)
« on: February 24, 2010, 05:19:25 PM »
I ran the machine just fine...left town...now it cannot find its way home! Y can Z can but X keeps bangin its head. The limit switch is o k.
What did I do wrong?
Woodenbug
Re: cannot reverse run from present feedhold
« Reply #1 on: February 24, 2010, 05:30:35 PM »
Attach your xml please.
« Reply #2 on: February 24, 2010, 05:35:19 PM »
 ??? What is xml?
« Reply #3 on: February 24, 2010, 05:40:10 PM »
« Reply #4 on: February 24, 2010, 05:46:44 PM »
xml is your config file, you will find it in the Mach3 folder, it will be called Mach3Mill.xml if you are using the standard profile, if you have a custom profile then it will have the name of the custom profile.
You will need to copy it to your desktop and rename it to woodenbug.xml or something like that as the forum will only accept a file name once and Mach3Mill will already have been attached.
« Reply #5 on: February 24, 2010, 05:59:55 PM »
w r - 408.xml
It is  a Camwood
« Reply #6 on: February 24, 2010, 06:04:30 PM »
You need to use the additional options button on the reply page to attach the xml.
« Reply #7 on: February 24, 2010, 06:23:23 PM »
Hood, I appreciate your help. But I am about as dumb as a stump when it comes to these machines and pc's.
I saw where it has an icon that says wr-408. Are you saying to copy that and rename it?
« Reply #8 on: February 24, 2010, 06:25:13 PM »
o k I found it! I will copy and paste.
« Reply #9 on: February 24, 2010, 06:32:17 PM »
I cannot paste it here.
