Hello Guest it is November 24, 2026, 04:06:44 AM
Author Topic: No screen adjustment after feed hold  (Read 15103 times)
« on: February 24, 2010, 01:22:08 PM »
I just updated to the newest lockdown version of Mach. When I am running a program and hit feed hold then move the  axis's from the current position, then when I hit cycle start again I am no longer getting the screen that usually would pop up before the axis move back to the position in the program.  I looked and I don't know what setting I am looking for, or if this is a bug.
Tom
Re: No screen adjustment after feed hold
« Reply #1 on: February 24, 2010, 04:10:01 PM »
Tom after a feed hold that is the correct operation.
You are thinking of RUN FROM HERE where you are asked for a preparation-al move
If YOU turned off the spindle when you used the feed hold, don't forget to TURN IT ON
Phil
« Reply #2 on: February 24, 2010, 04:16:27 PM »
Thanks, Phil... But in the old version a screen would pop up giving the XYZ coordinates and then the was a box to enter a rapid to position z Height and there was a check box to start the spindle.
Thanks Again,
Tom
« Reply #3 on: February 24, 2010, 04:29:19 PM »
Afraid I never do that as I always press run from here if I move away after a feedhold. I just tried simulating in the version I have loaded here and it didnt ask for a prep move to OK.
What version were you using previously?
« Reply #4 on: February 24, 2010, 05:18:33 PM »
The Version that it worked in was 3.041.  The window that would pop up has a title of Position preparation at the top.
Tom
« Reply #5 on: February 24, 2010, 05:26:39 PM »
Here is a screen shot of the box
« Reply #6 on: February 24, 2010, 05:29:55 PM »
Yes I know what the prep move is but I am glad you posted the screenshot as I see SmoothStepper in your profile. What Rev of SS plugin are you using and also after the feedhold are you pressing Stop so you can jog?
« Reply #7 on: February 24, 2010, 05:44:19 PM »
Just loaded 3.041 and yes I get the prep move box, not sure when it stopped doing that as I never use it but I will try different revisions and see if I can find the one it stopped with.
I am thinking  however it may have been changed deliberately  as the proper procedure would really  be a Run From Here, but thats just a guess ;D
Will see if Brian can shed any light on it.
« Reply #8 on: February 24, 2010, 05:47:17 PM »
After pressing feed hold I jog an axis away from the current position, then when I press start again the prep move screen pops up.  The version of smooth stepper in the most current one.  I have it installed in the old Mach and the new.
Tom
