Hello
Guest
it is
November 23, 2026, 01:19:58 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Speed and noise problem
« previous
next »
Print
Pages:
1
2
3
Go Down
Author
Topic: Speed and noise problem (Read 37901 times)
Carnoustie, Scotland
Re: Speed and noise problem
Reply #20 on:
February 21, 2010, 12:09:57 PM »
The code you attached is small, what size are you meaning it to be?
furkan
20
Reply #21 on:
February 21, 2010, 12:12:14 PM »
It must be bigger than 6 centimetres but I'm not sure because I didn't save the dxf file.
Reply #22 on:
February 21, 2010, 12:54:54 PM »
It sounds to me like you have forgotten to tell LazyCAM the units and it has assumed you were in inches.
Try doing some code with a wizard and make sure you choose its in mm if you get the option.
furkan
20
Reply #23 on:
February 21, 2010, 01:08:55 PM »
Ok. So I think no problem with hardware but the codes. I'll try to create a correct code and try again.
furkan
20
Reply #24 on:
February 21, 2010, 01:09:26 PM »
thanks a lot.
Print
Pages:
1
2
3
Go Up
« previous
next »
