Hello Guest it is November 23, 2026, 01:20:10 AM
Author Topic: Speed and noise problem  (Read 37903 times)
Re: Speed and noise problem
« Reply #10 on: February 21, 2010, 09:24:04 AM »
What have you got the steps per unit set to?
« Reply #11 on: February 21, 2010, 09:40:35 AM »
Now it is 907.0294776 . But I didn't give that value manuelly. I used the wizard for example I give the value 40 and it moved 15 millimetres instead of 40, then I entered 15 and software calculated it.
« Reply #12 on: February 21, 2010, 10:09:10 AM »
Can you please attach your xml and the code you were running.
« Reply #13 on: February 21, 2010, 10:19:14 AM »
This is the g-code that I created to try cnc. But I don't now how to have that xml file
« Reply #14 on: February 21, 2010, 10:22:58 AM »
If you are using the standard Mach3Mill profile then look in C:\Mach3 folder and copy the file called Mach3Mill.xml to your desktop then rename it to furkan.xml and attach to the forum.
« Reply #15 on: February 21, 2010, 10:25:46 AM »
a yes. here it is.
« Reply #16 on: February 21, 2010, 11:26:21 AM »
XML looks fine from what I can see.
 If you do the set steps wizard again what happens?
« Reply #17 on: February 21, 2010, 11:42:42 AM »
Now I did step wizard for the 3 axis. I enterd 80 and 3 of them moved 80 millimetres. But then I open the g code file that I send here, the machine drew it in  5 millimetres area.
« Reply #18 on: February 21, 2010, 11:52:20 AM »
The GCode file is about 3mm in X and about 4.5mm in Y.
Is it meant to be bigger?
Maybe your CAM is set in inches but not putting a G20 in so Mach thinks its in mm.
« Reply #19 on: February 21, 2010, 12:07:38 PM »
Oh I drow it in Ares (an electric circuit software) and used lazycam to convert dxf file to the gcode, it must be bigger.
Mach3 is set to metric.
(by the way, I appreciate you, even I'm not enough to understand you try to help me with patience.)
