Hello Guest it is November 10, 2026, 05:19:56 AM
Author Topic: Speed and noise problem  (Read 37544 times)
Re: Speed and noise problem
« Reply #20 on: February 21, 2010, 12:09:57 PM »
The code you attached is small, what size are you meaning it to be?
« Reply #21 on: February 21, 2010, 12:12:14 PM »
It must be bigger than 6 centimetres but I'm not sure because I didn't save the dxf file.
« Reply #22 on: February 21, 2010, 12:54:54 PM »
It sounds to me like you have forgotten to tell LazyCAM the units and it has assumed you were in inches.
Try doing some code with a wizard and make sure you choose its in mm if you  get the option.
« Reply #23 on: February 21, 2010, 01:08:55 PM »
Ok. So I think no problem with hardware but the codes. I'll try to create a correct code and try again.
« Reply #24 on: February 21, 2010, 01:09:26 PM »
thanks a lot.
