Hello
Guest
it is
November 10, 2026, 05:26:07 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
HELP! SLOW JOG SPEED PROBLEM
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: HELP! SLOW JOG SPEED PROBLEM (Read 25623 times)
freshwatermodels
54
Re: HELP! SLOW JOG SPEED PROBLEM
Reply #10 on:
February 20, 2010, 01:44:53 PM »
Maybe this is the correct XML
I have the max feed rate set at 100ipm I have the jog rate at 100% It seems to be jogging at about 10ipm
Have been running fine fro a long time until today when I fired up the router.
Once I figure this all out is there a way to lock all the settings?
Carnoustie, Scotland
Reply #11 on:
February 20, 2010, 01:55:07 PM »
Yes certainly something wrong, cant find it yet, will get back if I do.
freshwatermodels
54
Reply #12 on:
February 20, 2010, 02:01:47 PM »
Thanks, I hope you can help me sort this out. I was ready to make parts for customers and this issue stopped me dead in my tracks. Is reinstalling mach3 a reasonable way to go?
Reply #13 on:
February 20, 2010, 02:06:57 PM »
Making a new xml would probably work or maybe even using one of the backups, to do that go to Operator menu then Restore Settings and choose a day you think it worked.
Reply #14 on:
February 20, 2010, 02:17:50 PM »
Ok I think I found your problem, if you look on the diagnostics screen are the LEDs for the limits on? If so that is your problem as Mach thinks you are on a limit and will only allow a reduced rate jog speed.
Reply #15 on:
February 20, 2010, 02:19:21 PM »
Oh and you may also want to turn on Enahanced Pulsing on the General Config page, that is unless there was a reason you disabled it.
freshwatermodels
54
Reply #16 on:
February 20, 2010, 02:26:44 PM »
Thanks, that was very helpful!!! Problem solved! Interesting that the gecko didn't show a fault light. Now I know where to look if the problem occurs again. An afternoon lost BUT something learned.
jack
Reply #17 on:
February 20, 2010, 02:28:01 PM »
Happy milling
Print
Pages:
1
2
Go Up
« previous
next »
