Hello Guest it is November 23, 2026, 09:07:25 AM
Author Topic: HELP! SLOW JOG SPEED PROBLEM  (Read 25840 times)
« on: February 20, 2010, 12:01:34 PM »
I have been using Mach3 to run a router.   Today when I started it I can't get jog at 100%.   It is set at 100% but jogs ever so slowly.   I'm assuming I did something wrong but don't know what?  I am running a Gecko 540.    Limit switches and soft limits are set.
Any assistance appreciated!!!
Jack
Re: HELP! SLOW JOG SPEED PROBLEM
« Reply #1 on: February 20, 2010, 01:16:07 PM »
Please attach your xml.
« Reply #2 on: February 20, 2010, 01:21:37 PM »
I am having problems with attaching the file.   Will start a new thread
« Reply #3 on: February 20, 2010, 01:23:42 PM »
You will have to rename it to something that has never been attached on the forum before.
« Reply #4 on: February 20, 2010, 01:26:11 PM »
Try this
« Reply #5 on: February 20, 2010, 01:29:44 PM »
Thats not correct I am afraid, you need to attach the xml for the profile you are using.
« Reply #6 on: February 20, 2010, 01:30:38 PM »
Don't have a clue what you are talking about?
« Reply #7 on: February 20, 2010, 01:32:42 PM »
Ok if you use the standard Mach3Mill profile look in C:\Mach3 folder and copy the file called Mach3Mill.xml to your desktop then rename it and attach to the post. If you have a custom profile it will have the name of that custom profile. The xml you attached was a blank xml.
« Reply #8 on: February 20, 2010, 01:35:39 PM »
Maybe this is it???
« Reply #9 on: February 20, 2010, 01:38:31 PM »
Seems to work fine here, what speed are you seeing it jog at?
