Hello Guest it is November 10, 2026, 05:19:53 AM
Author Topic: HELP! SLOW JOG SPEED PROBLEM  (Read 25622 times)
Re: HELP! SLOW JOG SPEED PROBLEM
« Reply #10 on: February 20, 2010, 01:44:53 PM »
Maybe this is the correct XML
I have the max feed rate set at 100ipm    I have the jog rate at 100%     It seems to be jogging at about 10ipm
Have been running fine fro a long time until today when I fired up the router.
Once I figure this all out is there a way to lock all the settings?
« Reply #11 on: February 20, 2010, 01:55:07 PM »
Yes certainly something wrong, cant find it yet, will get back if I do.
« Reply #12 on: February 20, 2010, 02:01:47 PM »
Thanks, I hope you can help me sort this out.   I was ready to make parts for customers and this issue stopped me dead in my tracks.   Is reinstalling mach3 a reasonable way to go?
« Reply #13 on: February 20, 2010, 02:06:57 PM »
Making a new xml would probably work or maybe even using one of the backups, to do that go to Operator menu then Restore Settings and choose a day you think it worked.
« Reply #14 on: February 20, 2010, 02:17:50 PM »
Ok I think  I found your problem, if you look on the diagnostics screen are the LEDs for the limits on? If so that is your problem as Mach thinks you are on a limit and will only allow a reduced rate jog speed.
« Reply #15 on: February 20, 2010, 02:19:21 PM »
Oh and you may also want to turn on Enahanced Pulsing on the General Config page, that is unless there was a reason you disabled it.
« Reply #16 on: February 20, 2010, 02:26:44 PM »
Thanks,    that was very helpful!!!     Problem solved!    Interesting that the gecko didn't show a fault light.   Now I know where to look if the problem occurs again.  An afternoon lost BUT something learned.
jack
« Reply #17 on: February 20, 2010, 02:28:01 PM »
Happy milling :)
