Hello Guest it is November 14, 2026, 04:27:19 PM
Poll
what is best software for create a new screen
machscreen
10 (58.8%)
mach3screen
0 (0%)
screen4
7 (41.2%)
Total Members Voted: 17
Author Topic: Screen  (Read 78415 times)
Re: Screen
« Reply #20 on: February 19, 2010, 03:33:55 AM »
Hi Hood,
I didn't think memory space would be a problem. But if it is, no problem. I reduced the program memory space in version V1.38.f.
Klaus
The brain isn't a soap, it doesn't shrink when used.
Re: Screen
« Reply #21 on: February 19, 2010, 04:23:18 AM »
Klaus,
That was fast, you fixed a problem before you were asked. ;D
No excuses now Hood  ;D ;D ;D
Phil
Re: Screen
« Reply #22 on: February 19, 2010, 07:23:33 AM »
No MachScreen 480Mb
With MachScreen 680Mb
Phil
Re: Screen
« Reply #23 on: February 19, 2010, 12:52:04 PM »
Klaus
 will check it out tomorrow, been working away from the workshop today.
Phil
 Dont need an excuse not to use it as I have a reason not to ;)
Re: Screen
« Reply #24 on: February 19, 2010, 01:47:48 PM »
My humble opinion, is that anyone not voting for Machscreen, haven't used it, yet ;)
Re: Screen
« Reply #25 on: February 19, 2010, 03:49:09 PM »
What do you do for design a screen 1024-768 ?
Use Screen 4 running at 1280x1024. :)
Re: Screen
« Reply #26 on: February 20, 2010, 05:30:44 AM »
I have used both Screen4 and Machscreen for detailed screen designs. Since I switched over to Machscreen my productivity has increase 3 folds. My vote goes to Machscreen.
Zafar
Re: Screen
« Reply #27 on: February 20, 2010, 11:34:15 AM »
My vote goes to MachScreen. I used it the other day for the first time and found it very intuative and the layout is simple, very similar to the Visual Basic development software I sometimes use where you have a window sidebar selection to change the properties.
Only two annoyances I found, The dropdown box for the selection of Mach screen page. With the previous version it worked ok, I downloaded and install the latest version
and found the box does not dropdown so you have to click the scroll until your numbers there and then select.
The other thing happened with both versions, on saving the file I get a errorbox  with filename name or directory name syntax wrong but it saves ok.
All in all, It works without weird things happening and you can make changes to you screen easily.
Re: Screen
« Reply #28 on: February 20, 2010, 11:43:54 AM »
Hi cjmerlin,
did you deinstall the old version before you installed v1.38.f?
When do you get the save error, when saving, or saving as?
Could you please give me the complete error message?
Klaus
Re: Screen
« Reply #29 on: February 20, 2010, 12:31:46 PM »
I cant remember if I uninstalled the previous version, probably not.
Error on both save and save as, have to press ok twice ie 2 boxes po
