Hello
Guest
it is
November 22, 2026, 06:34:54 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Record encoder position
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Record encoder position (Read 10164 times)
zzzox
2
on:
February 17, 2010, 12:57:28 PM »
I attached encoder on the parallel port and read position on the encoder input DRO.
Can the Mach to record position and generate code?
Thanks in advance
Overloaded
4,923
Re: Record encoder position
Reply #1 on:
February 17, 2010, 07:10:05 PM »
Brians JCode plugin might do just what you want. Jog-> GCode
I would guess that it would work the same with an MPG as it does with the jog hotkeys.
There is a video on it under the SUPPORT tab.
Hope this is what you want,
Russ
Reply #2 on:
February 17, 2010, 08:09:44 PM »
If you want to copy something via axis moves and generate the Gcode to machine it you may want to look at using CopyCat. The manual for it can be found in Members Docs.
Print
Pages:
1
Go Up
« previous
next »
