Hello Guest it is November 25, 2026, 09:46:32 PM
Author Topic: Record encoder position  (Read 10184 times)
« on: February 17, 2010, 12:57:28 PM »
I attached encoder on the parallel port and read position on the encoder input DRO.
Can the Mach to record position and generate code?
Thanks in advance
Re: Record encoder position
« Reply #1 on: February 17, 2010, 07:10:05 PM »
Brians JCode plugin might do just what you want.      Jog-> GCode
I would guess that it would work the same with an MPG as it does with the jog hotkeys.
There is a video on it under the SUPPORT tab.
Hope this is what you want,
Russ
« Reply #2 on: February 17, 2010, 08:09:44 PM »
If you want to copy something via axis moves and generate the Gcode to machine it you may want to look at using CopyCat. The manual for it can be found in Members Docs.
