Hello Guest it is November 13, 2026, 09:45:01 AM
Author Topic: Program start from a tool number  (Read 11305 times)
« on: February 12, 2010, 11:17:38 AM »
Is there a way to start running a gcode program by specifying a tool number example "tool breakage"
because when i scroll down thru the gcode window and select "run from here" button in mach it ask for a prep move that is even relevant to the part
Adam
Re: Program start from a tool number
« Reply #1 on: February 12, 2010, 01:47:57 PM »
Sorry dont follow what you are asking, can you try and explain a bit more please.
Offline bowber
  •  216 216
  • Kirkby Stephen,Cumbria, UK
« Reply #2 on: February 13, 2010, 05:51:46 AM »
I think Adam is asking if you can "run from here" without the prep move.
Steve
