Hello
Guest
it is
November 13, 2026, 05:23:44 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
General CNC Chat
Show"N"Tell ( What you have made with your CNC machine.)
What i didn't make with my cnc machine
« previous
next »
Print
Pages:
1
2
3
Go Down
Author
Topic: What i didn't make with my cnc machine (Read 48939 times)
spunk
56
on:
February 12, 2010, 10:47:29 AM »
Perhaps a good idea for the disaster tourists among us...
come forward and don't be ashamed...
here's my latets one
Already made some adaptors for the 45W servo motor from cncdrive with the sherline and thought i'd give the last one on the stepperdrive...
http://www.youtube.com/watch?v=9nygwBmlYIo
forgot to tighten the bolt from the morse cone...
hahahahah
Last Edit: February 12, 2010, 10:49:20 AM by spunk
Re: What i didn't make with my cnc machine
Reply #1 on:
February 12, 2010, 11:19:26 AM »
What bothered me more was that you are using the drill chuck instead of a collet.
Forgetfull once is forgiven, but not using a collet, well no sympathy, so you get 20 whippings
and must spend the night in the chuck repair doghouse.
spunk
56
Reply #2 on:
February 12, 2010, 02:28:07 PM »
the drill chuck works perfectly for small bits... there are several more issues if your looking for them do....
SScnc
77
Reply #3 on:
February 14, 2010, 06:52:45 AM »
Your lucky it didn't pull the chuck off its taper. Big time no no
vintageracer
Reply #4 on:
February 14, 2010, 06:48:03 PM »
ouch.
That could have been alot worse though.
Timothy
spunk
56
Reply #5 on:
February 15, 2010, 12:56:17 AM »
i know i know
but don't hesitate to share your mistakes...
don't let me be the only one
come one everybody, make my day
vintageracer
Re: What I didn't make with my cnc machine
Reply #6 on:
February 15, 2010, 11:04:55 AM »
Fair enough.
The drill on the left had the feedrate set at 200% cause I was playing with the previous cutter and didn't reset the overrides.
The end mill on the right didn't have any coolant cause I typed a M09 instead of a M08.
Timothy
Last Edit: February 15, 2010, 11:06:26 AM by naught2ferrous
vintageracer
Reply #7 on:
February 15, 2010, 12:42:01 PM »
I did a bit of searching on eBay and I found a reasonably priced ER16 collet chuck for a MT taper.
http://cgi.ebay.com/ER16-MT2-M10-Collet-Chuck-Milling-Lathe-A-Spanner-US_W0QQitemZ170443661805QQcmdZViewItemQQptZBI_Tool_Work_Holding?hash=item27af3be1ed#ht_715wt_871
I highly recommend you look into replacing that drill chuck.
You will see an improvement right away.
Timothy
spunk
56
Reply #8 on:
February 15, 2010, 01:40:19 PM »
timothy,
does that collet fit a sherline strait away?
would be awesome handy
RIP for your drill and mill
vintageracer
Reply #9 on:
February 15, 2010, 02:24:26 PM »
I checked the Sherline website and all the mill models have a MT1 spindle taper.
So, this one here will fit....
http://cgi.ebay.com/ER11-MT1-M6-Collet-Chuck-Milling-Lathe-A-Spanner-US_W0QQitemZ180467157299QQcmdZViewItemQQptZBI_Tool_Work_Holding?hash=item2a04ae4933#ht_681wt_871
Its an ER11 collet chuck. I think the ER16 might be too big.
and a collet set from the same retailer.
http://cgi.ebay.com/ER11-collets-set-11pcs-2-7mm-milling-lathe-CNC-US_W0QQitemZ170436008333QQcmdZViewItemQQptZBI_Tool_Work_Holding?hash=item27aec7198d#ht_756wt_754
Timothy
Print
Pages:
1
2
3
Go Up
« previous
next »
