Hello Guest it is November 13, 2026, 05:16:37 PM
Author Topic: What i didn't make with my cnc machine  (Read 48932 times)
Offline spunk
  •  56 56
« on: February 12, 2010, 10:47:29 AM »
Perhaps a good idea for the disaster tourists among us...
come forward and don't be ashamed...
here's my latets one
Already made some adaptors for the 45W servo motor from cncdrive with the sherline and thought i'd give the last one on the stepperdrive...
http://www.youtube.com/watch?v=9nygwBmlYIo
forgot to tighten the bolt from the morse cone...
hahahahah :D ;D
« Last Edit: February 12, 2010, 10:49:20 AM by spunk »
Re: What i didn't make with my cnc machine
« Reply #1 on: February 12, 2010, 11:19:26 AM »
What bothered me more was that you are using the drill chuck instead  of a collet.
Forgetfull once is forgiven, but not using a collet, well no sympathy, so you get 20 whippings
and must spend the night in the chuck repair doghouse.  ;D
Offline spunk
  •  56 56
« Reply #2 on: February 12, 2010, 02:28:07 PM »
the drill chuck works perfectly for small bits... there are several more issues if your looking for them do.... :D
Offline SScnc
  •  77 77
« Reply #3 on: February 14, 2010, 06:52:45 AM »
Your lucky it didn't pull the chuck off its taper. Big time no no
vintageracer
« Reply #4 on: February 14, 2010, 06:48:03 PM »
ouch.
That could have been alot worse though.
Timothy
Offline spunk
  •  56 56
« Reply #5 on: February 15, 2010, 12:56:17 AM »
i know i know
but don't hesitate to share your mistakes...
don't let me be the only one  :-[
come one everybody, make my day
vintageracer
Re: What I didn't make with my cnc machine
« Reply #6 on: February 15, 2010, 11:04:55 AM »
Fair enough.
The drill on the left had the feedrate set at 200% cause I was playing with the previous cutter and didn't reset the overrides.
The end mill on the right didn't have any coolant cause I typed a M09 instead of a M08.
Timothy
« Last Edit: February 15, 2010, 11:06:26 AM by naught2ferrous »
vintageracer
« Reply #7 on: February 15, 2010, 12:42:01 PM »
I did a bit of searching on eBay and I found a reasonably priced ER16 collet chuck for a MT taper.
http://cgi.ebay.com/ER16-MT2-M10-Collet-Chuck-Milling-Lathe-A-Spanner-US_W0QQitemZ170443661805QQcmdZViewItemQQptZBI_Tool_Work_Holding?hash=item27af3be1ed#ht_715wt_871
I highly recommend you look into replacing that drill chuck.
You will see an improvement right away.
Timothy
Offline spunk
  •  56 56
« Reply #8 on: February 15, 2010, 01:40:19 PM »
timothy,
does that collet fit a sherline strait away?
would be awesome handy :o :D
RIP for your drill and mill  :D
vintageracer
« Reply #9 on: February 15, 2010, 02:24:26 PM »
