Hello Guest it is November 13, 2026, 06:15:15 PM
Author Topic: X axis stopped working  (Read 10255 times)
« on: February 06, 2010, 12:14:02 PM »
I have been running Mach3 with Dell 800 for 3 months on a 4 axis machine. The X axis stopped working suddenly.
I have checked the LPT port motor output pins for voltage. Y, A, and B look the same. DIR 0-5V, Step 0-50mV. Y, A, and B work. X stopped working. DIR shows 0-5 v Step shows 80mv -130mv at the port pin. DRO moves but no motor movement.
I have verified the X axis wiring and motor are good on the other axis.
I have check the LPT port with a printer and it works.
The strange thing is if I swap the Step and Dir pins in the setup I get good voltage readings. (but my driver board can't use it like that).
Thoughts appreciated.
(I would like to get some sleep.)
Re: X axis stopped working
« Reply #1 on: February 06, 2010, 12:21:00 PM »
Port 1   0x378
Motor Output
   Enabled   Step   Dir   Dir Low   Step Low   Step Port    Dir Port
X axis   Yes   14   4   x   x   1   1
Yaxis   Yes   2   17   x   x   1   1
A axis   Yes   3   8   x   x   1   1
B axis   Yes   5   9   x   x   1   1
Inputs
Estop   Yes   Port 1   Pin 10    Act LOW
Output Signals
Enable    Port   Pin
1   1   1
2   1   7
3   1   6
4   1   6
« Reply #2 on: February 06, 2010, 01:22:34 PM »
Try swapping the drives around, sounds like a hardware problem.
