Hello
Guest
it is
November 13, 2026, 11:53:10 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
locked motor
« previous
next »
Print
Pages:
1
2
3
4
Go Down
Author
Topic: locked motor (Read 55076 times)
Stubby1
22
locked motor
on:
February 01, 2010, 10:31:53 PM »
Hi, I a noob to the CNC world. I have finished my machine and now trying to get the software, boards, and motors to talk to each other. I have ran the driver test on my Tobshiba satellite laptop with excellent results and set up the software the seller of the interface and driver boards but with no luck on getting the motor to turn. I am test one motor here in the house then I will move out to the shop when completed. The motor appears to be lock when the power is applied. I have tried several different setups, on a PC, and another motor with no luck. The LEDs on the driver board and a multimeter show a constant voltage to one side of the motor. Using Danaher 2 phase 1.8 degree stepper motors.
Any help or suggestions before I ruin something?
John
Independence, OR
Last Edit: February 01, 2010, 10:43:33 PM by Stubby1
Logged
Carnoustie, Scotland
Re: locked motor
Reply #1 on:
February 02, 2010, 01:23:57 AM »
can you attach your xml please, also any documents (or a link) for the wiring.
Logged
Stubby1
22
Re: locked motor
Reply #2 on:
February 02, 2010, 02:17:30 AM »
Will this work?
Logged
Re: locked motor
Reply #3 on:
February 02, 2010, 09:49:37 AM »
Will have a look tonight when I get home, busy day today in the workshop
Logged
dragonfinder1
57
Re: locked motor
Reply #4 on:
February 02, 2010, 10:05:20 AM »
The motors should lock up when the power is applied. That means the power has made through the drives. Now you need to get Mach set up, not an easy task when you first look at it, but really not that hard and the folks here love to help.
Logged
Re: locked motor
Reply #5 on:
February 02, 2010, 03:41:46 PM »
These manuals are not very cear at all, or at least to me they are not.
What wires have you got hooked up at the moment and to where?
Logged
bowber
216
Kirkby Stephen,Cumbria, UK
Re: locked motor
Reply #6 on:
February 02, 2010, 03:43:06 PM »
When you do wire up just do one axis and get that working how you want it, then do the rest.
Steve
Logged
Stubby1
22
Re: locked motor
Reply #7 on:
February 02, 2010, 03:56:27 PM »
Bowber: That is what I am doing now. One axis at a time.
Here is a picture of one driver and the how I have the wire connected.
I paired up the wires doing a continuity check.
Logged
Re: locked motor
Reply #8 on:
February 02, 2010, 04:02:32 PM »
On the breakout do you have a power supply (or USB) connected?
If you open Mach are the motors locked when the Reset is flashing or is it after the Reset is green that they lock?
Logged
Stubby1
22
Re: locked motor
Reply #9 on:
February 02, 2010, 04:05:23 PM »
I am using a power supply and connect at the + / -
The motor is locked when power is supplied. Doesn't seem to matter when reset or not.
I done the driver test in Mach and come out with excellent results.
Logged
Print
Pages:
1
2
3
4
Go Up
« previous
next »
