Hello Guest it is November 23, 2026, 01:04:06 PM
Author Topic: Good servo tune in Axis Works is way different in Mach 3 ??  (Read 8525 times)
« on: January 18, 2010, 02:49:18 PM »
I can get my servo motors tuned pretty good in Axis Works but when I start Mach 3 they act totally different and out of tune. I have checked and double checked everything. I Make sure the velocity and torque is all the same as I used in axis works. I have uploaded the xml file multiple times. My PIDS have to be sky high to operate in Mach 3 verses what was good in Axis Works. I can manually inspect the XML and the settings are what I saved in Axis Works and there isn't a problem. I go back to Axis Works and all runs smooth as is. I just dint know what I'm doing wrong.
