Hello Guest it is November 01, 2026, 10:13:39 AM
Author Topic: Quick questions about LazyCam  (Read 33167 times)
Offline gaz.
  •  23 23
« on: January 14, 2010, 12:07:12 PM »
Hello,
I am importing text from corel draw into LazyCam,  all that works fone but how can i get the path to cut the inside of the letters first i.e cut the circle out of the "a" and then the outside, because at the moment is does the outside , then the letter is moving when it is doing the inside  :-[
I have been searching for a fix now for ages but couldnt find anything,  could someone please explain how to do it or point me to a thread please.
Thanks in advance.
Gaz.
Re: Quick questions about LazyCam
« Reply #1 on: January 14, 2010, 01:13:51 PM »
Have you taken a look at Tutorial #4 in the LazyCam Manual on text?
Offline gaz.
  •  23 23
« Reply #2 on: January 14, 2010, 01:24:44 PM »
Where can i find the manual.  I have downloaded something to do with lazycam from the support section but no luck there.
Gaz.
« Reply #3 on: January 14, 2010, 01:44:17 PM »
Here is the link. About everything I know and can't remember is in that manual.  :)
http://www.machsupport.com/forum/index.php/topic,12078.msg77415.html#msg77415
Offline gaz.
  •  23 23
« Reply #4 on: January 14, 2010, 01:46:37 PM »
Cheers Bud! ;D
« Reply #5 on: January 14, 2010, 01:52:05 PM »
Happy reading it all,  >:D  the tutorials build on each other so don't skip any and take a look in the back and you will see
a listing of kown bugs.
Offline jasko
  •  14 14
« Reply #6 on: July 06, 2010, 09:13:23 AM »
Hi
can anybody tell me is it possible to use newest version of Mach without LC
Importing PLT files directly in Mach from Corel  is much easier because you define layers in Corel with different colors and just set speed and depth
« Reply #7 on: July 06, 2010, 09:34:33 AM »
JASKO,
You need to provide a file which contains the code to machine the part ( ie; a file which has Gcode).
So if Corel can post process the information into a file used for machining you would be good to go!
You can use Mach without LC installed.
Offline jasko
  •  14 14
« Reply #8 on: July 06, 2010, 01:02:02 PM »
I understand  this but new version of Mach don't have import option
« Reply #9 on: July 06, 2010, 05:53:52 PM »
Someone posted a link to the old importer the other day, but I don't know where it's at. Somewhere here in the forum.
