Hello Guest it is November 03, 2026, 11:07:46 AM
Author Topic: 1987 Bridgeport Production Center Interact 412 to Mach3 Conversion  (Read 635912 times)
Re: 1987 Bridgeport Production Center Interact 412 to Mach3 Conversion
« Reply #80 on: October 01, 2010, 04:01:10 PM »
With the machine basically functional, I thought I would snap a couple of pics of the electronics used before the all the sheet metal is back on.
JH
« Reply #81 on: October 01, 2010, 08:09:44 PM »
Good stuff, Joel. Thanks for sharing it with us!
« Reply #82 on: October 04, 2010, 12:11:21 PM »
Got some time on the Control Panel between coats of paint.  Added a keyboard with build in mouse / track ball.  Made the buttons labels on the vinyl plotter.  Only a couple of buttons are functional now.  Need to hook up the PoKeys next for the rest...
JH
Offline N4NV
  •  398 398
« Reply #83 on: October 04, 2010, 10:39:00 PM »
Where did you get your square buttons?
Vince
« Reply #84 on: October 05, 2010, 08:15:43 AM »
I'm guessing an arcade game supplier?
« Reply #85 on: October 05, 2010, 09:08:43 AM »
Vince
Good guess Dave !  Mine as well.
Russ
http://www.machsupport.com/forum/index.php/topic,13365.msg107233.html#msg107233
« Reply #86 on: October 05, 2010, 11:38:04 AM »
Yep, these are Arcade Video Game Buttons.  Nice too, LED back light with SPDT micro switch.  Got em off of ebay from user hklwh123 but there are many others that sell the same ones, some rectangle and some round.
I bought just a couple to to make sure the quality was good and to measure them, then went back and bought the rest with a couple of spares.
JH
« Reply #87 on: October 08, 2010, 10:52:47 AM »
Been painting and putting the sheet metal back on in phases while making sure all the parts fit right.  Made a simple way cover for Y Axis out of some rubber sheeting and 6061.  Added a couple of 120VAC computer fans with external filters to cool the cabinet.
Its starting to look nice now, its sooooo much cleaner that when I started.  Thinking I'll need to add some graphics to that blank canvas before its over....
JH
« Reply #88 on: October 08, 2010, 11:02:07 AM »
Here are some quick pics of the remaining sheet metal in work.  Degrease, sand, grind, weld holes....
JH
Offline cnc-it
  •  153 153
« Reply #89 on: October 08, 2010, 12:42:23 PM »
Hi JH looks really nice! Do you spray the paint on or use a roller?
Would have stuck to the flexi metal y axis cover which hangs over the turcite coated brackets though. I've found the rubber type can snag on the table front during x axis moves and also sag onto the ball screw when the swarf starts building up!!
John
