Hello Guest it is October 13, 2026, 04:07:05 PM
Author Topic: A Short Video.  (Read 14882 times)
  •  9,374 9,374
A Short Video.
« on: December 05, 2009, 10:59:32 AM »
Just a bit of fun really, but I decided to make a couple of short videos to put on my website. The hardest part was adjusting the feedrate so that the job took the same length of time as the musical score.
This one is a bit better than my first video but I think that more practice is needed.
                   http://www.tweakie.byethost.com/engrave1.wmv
« Last Edit: May 31, 2018, 07:19:46 AM by Tweakie.CNC »
Re: A Short Video.
« Reply #1 on: December 05, 2009, 04:24:15 PM »
I can't see the video, link does not work for me
Jeff
Re: A Short Video.
« Reply #2 on: December 05, 2009, 09:44:41 PM »
 ;D Good stuff Tweakie. Didn't know what it was till 1:00.
Jeff: right click the link, and save it to your computer. Then open it. It's in standard windows format, so there should be no problem if your using windows. It may not open correctly if you just click the link.
« Last Edit: December 05, 2009, 09:47:51 PM by Sam »
  •  9,374 9,374
Re: A Short Video.
« Reply #3 on: December 06, 2009, 03:13:57 AM »
You are way ahead of me Sam, I didn't know what it was until I was 10 Years old !!!.  ;D ;D
« Last Edit: December 06, 2009, 11:03:12 AM by Tweakie.CNC »
Offline BarryB
  •  267 267
Re: A Short Video.
« Reply #4 on: December 06, 2009, 12:12:32 PM »
it took me the same time 1:00 that is.  Fun stuff.
Re: A Short Video.
« Reply #5 on: December 16, 2009, 03:58:37 PM »
Hi Tweekie,
What cutter type
What motor spinde speed
What cut depth
What material used.
 ;D ;D ;D ;D
Lots of questions from a newbie  ;D
By the way. Great dem, great music, great result
Len-Tik
One step at a time!
  •  9,374 9,374
Re: A Short Video.
« Reply #6 on: December 17, 2009, 02:28:37 AM »
Hi Len-Tik,
Cutter is a standard carbide engraving bit 30 degrees angle.
Spindle speed was 3000 rpm.
The cut depth was -0.2 mm.
And the material is Traffolite (a standard engraving laminate).
Glad you enjoyed the video - There is another one here http://www.flickr.com/photos/tweakie-cnc/4174280038/ this time it's a PCB.
