Hello Guest it is October 03, 2026, 08:58:35 PM
Author Topic: another parallel port question  (Read 26695 times)
Re: another parallel port question
« Reply #10 on: December 02, 2009, 08:35:47 AM »
I'm using the Wolfgang spindle and I purchased my bits from you Jeff!
I think the WG spindle is 18K+ RPM and I only use it for PCBs. I have a Porter Cable that I will press into service when I start wood working.
I have been setting my XY speed to 30ipm in pcb-gcode.
SmoothStepper, hmmm I should look into one.
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
« Reply #11 on: December 02, 2009, 08:52:12 AM »
So you'll have the spindle speed you need then! I know when I started milling PCBs I was feeding too fast as I was being impatient, and like to help other folks avoid the mistakes I made. Glad to hear your using the PreciseBits  ;D
Happy machining , Jeff Birt
« Reply #12 on: December 02, 2009, 09:03:51 AM »
Just curious Jeff, are the bits you are talking about HSS?
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
« Reply #13 on: December 02, 2009, 09:27:49 AM »
Nope, not HSS. The FR4 PCB laminate would chew up HSS in short order. I sell the solid submicrograin carbide bits made by PreciseBits: http://soigeneris.com/PreciseBitsPCB.aspx.
« Reply #14 on: December 02, 2009, 09:34:50 AM »
Ok, thanks, just seemed a bit slow to me but then again I am used to machining metals which obviously is a different thing.
« Reply #15 on: December 02, 2009, 11:35:17 AM »
Sorry I have another one?
Is there a relationship between kernel speed and processor speed? 100K kernel speed requires a minimum CPU of X value?
