Hello Guest it is November 13, 2026, 06:44:42 PM
Author Topic: 1-Port Parallel PCI Card  (Read 81689 times)
Re: 1-Port Parallel PCI Card
« Reply #50 on: December 01, 2009, 04:37:05 PM »
yeah many many! Praise Microsoft!
« Reply #51 on: December 01, 2009, 04:37:37 PM »
Found xml thingy!
Will try to attach
« Reply #52 on: December 01, 2009, 04:50:56 PM »
not sure this is my custom profile..
« Reply #53 on: December 01, 2009, 04:55:52 PM »
Ok will have a look in a few mins but just in case you misunderstood regards the patch, it is on the Mach downloads page and is needed I think  for using Mach under Vista.
« Reply #54 on: December 01, 2009, 04:58:03 PM »
If that was the xml you had loaded when testing the Dir pin for voltage it is Pin 6 you need to test.
« Reply #55 on: December 01, 2009, 05:00:21 PM »
Also, have you got an E-Stop switch fitted? if not then you will either need to short pin 13 to Gnd or change the active state of the E-Stop in ports and Pins, Inputs. If you dont do that then you will not be able to get Mach out of Reset and thus wont be able to jog.
« Reply #56 on: December 01, 2009, 05:08:59 PM »
No i've looked that must be the one for the non custom profile (which has pin 6 enabled). I'll try and find the correct one and attach tomorrow. I've gotta get some sleep now.. brain hurts.
No. Thats not it I auto toggled all pins preventing reset.
Thanks again Jolyon
« Reply #57 on: December 01, 2009, 05:11:55 PM »
also Mach definately jogging, numbers go up and down! Goodnight and cheers:)
« Reply #58 on: December 01, 2009, 05:53:13 PM »
Have you run the driver test?
« Reply #59 on: December 02, 2009, 12:56:11 PM »
Heya Hood
Driver test?
