Hello Guest it is November 13, 2026, 06:44:33 PM
Author Topic: 1-Port Parallel PCI Card  (Read 81684 times)
Re: 1-Port Parallel PCI Card
« Reply #40 on: December 01, 2009, 03:55:40 PM »
You could also verify the address by going to Start, All Programmes, Accessories, System Tools, System Information. Once there go to Components then down to Ports and finally Parallel.
« Reply #41 on: December 01, 2009, 03:58:42 PM »
they are lighting up the amber leds for M1 M2 and M3
« Reply #42 on: December 01, 2009, 04:02:02 PM »
If they are lighting when you short then the Inputs are working and you definitely have the correct address set.
If you want to attach your xml I will have a glance through it to see if I can find a problem ther.
« Reply #43 on: December 01, 2009, 04:04:07 PM »
looked where you said in components ports parallel and nothing there!
By the way what is an xml? sorry!
« Reply #44 on: December 01, 2009, 04:08:02 PM »
the xml is your profiles settings. If you are using the standard Mach3Mill profile that is the xml you want, ie Mach3Mill.xml. You will find it in the main Mach 3 folder on your drive. If you made a custom profile then the xml will have the name of that custom profile.
You will need to copy and rename the xml for the forum to accept it, renaming to noyloj.xml should do the trick :)
« Reply #45 on: December 01, 2009, 04:18:07 PM »
Cant find MACH3Mill.xml
Can find MACHXML but it looks like a RAR file maybe
can also find xml backups.. Any good?
« Reply #46 on: December 01, 2009, 04:23:48 PM »
No, backups are a pain to look at, you may not be seeing the file extensions as windows hides them by default for known extensions. To disable that you can go to Tools menu when in a folder in windows, then down to folder options . When that window pops up go to view and then down and take the check mark out of Hide known file extensions. Save and then refresh the Mach3 folder and you should now see the file extensions.
« Reply #47 on: December 01, 2009, 04:30:12 PM »
Man I am so dumb how do I get Tools menu when in folder? (I'm running vista)
« Reply #48 on: December 01, 2009, 04:35:10 PM »
Ah ok, well dont have a clue I am afraid, dont like Vista so have never messed with it.
You should still see the xml but it will just be called Mach3Mill with no file extension.
« Reply #49 on: December 01, 2009, 04:36:17 PM »
Have you installed the patch for Vista?
