Hello
Guest
it is
November 13, 2026, 06:44:41 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
1-Port Parallel PCI Card
« previous
next »
Print
Pages:
1
2
3
4
5
6
7
Go Down
Author
Topic: 1-Port Parallel PCI Card (Read 81688 times)
noyloj
35
Re: 1-Port Parallel PCI Card
Reply #10 on:
November 29, 2009, 02:03:19 PM »
Okay I'm looking at the inputs section on ports and pins but I dont see X limit only x ++, x --, x home?
Logged
Carnoustie, Scotland
Reply #11 on:
November 29, 2009, 02:04:48 PM »
Any will do.
Logged
noyloj
35
Reply #12 on:
November 29, 2009, 02:08:29 PM »
I have checked box for enable x home, port 1, pin 12, do i have to check active low or emulated?
Logged
Reply #13 on:
November 29, 2009, 02:16:25 PM »
You can check active low if you wish, that will mean the LED on the diagnostics will light when you short, if you leave it active high then it will go out when you short. Make sure you have it enabled but there is no need for the emulation.
Logged
noyloj
35
Reply #14 on:
November 29, 2009, 02:20:51 PM »
okay when i dont check active low i cannot reset until i togle to active low (the program offers to do this for me). However I dont seem to get any response shorting out pin 12 to pin 25?
Logged
Reply #15 on:
November 29, 2009, 02:24:01 PM »
You dont need to worry about the reset, the LED should react even when Mach is in reset.
Logged
noyloj
35
Reply #16 on:
November 29, 2009, 02:32:46 PM »
okay no joy with pin 12, however i have enabled the inputs to port 1 and can seem to switch leds on and off...
Logged
noyloj
35
Reply #17 on:
November 29, 2009, 02:34:24 PM »
even though i haven't assigned any pin numbers?!
Logged
Reply #18 on:
November 29, 2009, 02:38:03 PM »
Dont see how that could be possible, can you attach a screenshot of what you have set and tell me which pins you are shorting to switch the LED.
Logged
noyloj
35
Reply #19 on:
November 29, 2009, 02:41:56 PM »
Duh sorry this is all very new to me.. How do I take snapshot of screen and attach?
Logged
Print
Pages:
1
2
3
4
5
6
7
Go Up
« previous
next »
