Hello
Guest
it is
November 13, 2026, 09:08:24 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
ShuttlePro startup
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: ShuttlePro startup (Read 11939 times)
MarkC
94
ShuttlePro startup
on:
November 28, 2009, 11:41:52 AM »
Is it possible to set the "startup state" or default state of the ShuttlePro functions?
I'd like it to be locked and have z jog at startup
Mark
Mark
MarkC
94
Re: ShuttlePro startup
Reply #1 on:
December 01, 2009, 07:16:42 PM »
Bump
Mark
MarkC
94
Reply #2 on:
December 04, 2009, 06:36:56 PM »
Anyone?
Mark
Carnoustie, Scotland
Reply #3 on:
December 04, 2009, 06:43:49 PM »
Sorry have never had or used one so not sure how it works. Does it all work within the plugin or do you set buttons and such up with Brains or in Ports and Pins? If you do it all in the plugiin then probably not possible unless that functionality was added to the plugin. If its Brains or OEM triggers then you should be able to do via a macro.
MarkC
94
Reply #4 on:
December 05, 2009, 10:51:50 AM »
Thanks for replying, Hood.
It works with a plugin; I can't find anywhere else to make any settings, so I'm going to assume that it can't be done at this time.
Maybe add it to a wishlist for a future version?
Thanks again
Mark
Mark
Print
Pages:
1
Go Up
« previous
next »
