Mach Discussion => General Mach Discussion => Topic started by: MarkC on November 28, 2009, 12:41:52 PM
Title: ShuttlePro startup
Post by: MarkC on November 28, 2009, 12:41:52 PM
Is it possible to set the "startup state" or default state of the ShuttlePro functions?
I'd like it to be locked and have z jog at startup
Mark
Title: Re: ShuttlePro startup
Post by: MarkC on December 01, 2009, 08:16:42 PM
Bump
Post by: MarkC on December 04, 2009, 07:36:56 PM
Anyone? ???
Post by: Hood on December 04, 2009, 07:43:49 PM
Sorry have never had or used one so not sure how it works. Does it all work within the plugin or do you set buttons and such up with Brains or in Ports and Pins? If you do it all in the plugiin then probably not possible unless that functionality was added to the plugin. If its Brains or OEM triggers then you should be able to do via a macro.
Post by: MarkC on December 05, 2009, 11:51:50 AM
Thanks for replying, Hood.
It works with a plugin; I can't find anywhere else to make any settings, so I'm going to assume that it can't be done at this time.
Maybe add it to a wishlist for a future version? ;D
Thanks again
Mark
