Hello Guest it is November 13, 2026, 08:07:22 PM
Author Topic: ShuttlePro startup  (Read 11933 times)
Offline MarkC
  •  94 94
ShuttlePro startup
« on: November 28, 2009, 11:41:52 AM »
Is it possible to set the "startup state" or default state of the ShuttlePro functions?
I'd like it to be locked and have z jog at startup
Mark
Mark
Offline MarkC
  •  94 94
Re: ShuttlePro startup
« Reply #1 on: December 01, 2009, 07:16:42 PM »
Bump
Mark
Offline MarkC
  •  94 94
« Reply #2 on: December 04, 2009, 06:36:56 PM »
Anyone? ???
Mark
« Reply #3 on: December 04, 2009, 06:43:49 PM »
Sorry have never had or used one so not sure how it works. Does it all work within the plugin or do you set buttons and such up with Brains or in Ports and Pins? If you do it all in the plugiin then probably not possible unless that functionality was added to the plugin. If its Brains or OEM triggers then you should be able to do via a macro.
Offline MarkC
  •  94 94
« Reply #4 on: December 05, 2009, 10:51:50 AM »
Thanks for replying, Hood.
It works with a plugin; I can't find anywhere else to make any settings, so I'm going to assume that it can't be done at this time.
Maybe add it to a wishlist for a future version? ;D
Thanks again
Mark
Mark
