Hello Guest it is October 23, 2026, 06:16:56 PM
Author Topic: Sudden stop  (Read 11459 times)
Sudden stop
« on: November 14, 2009, 07:57:23 AM »
I was machining a small detailed piece and the machining suddenly stopped.  The file size is about 4 meg, with 320,000 lines of GCode.
I seem to remember something about the display being a problem, but I have been machining similar files without a stop.
Is there any way to find what makes Mach3 stop?
Are newer versions better? (I am running version R2.0.047)
Richard
  •  9,374 9,374
Re: Sudden stop
« Reply #1 on: November 14, 2009, 09:14:25 AM »
It would be helpful if you could provide more details.
Was anything shown in the Status box after the stop ?
Was it an e-stop or limit switch triggered (Reset flashing) ?
Re: Sudden stop
« Reply #2 on: November 16, 2009, 12:12:04 PM »
Sorry for the delay in replying.  I did not take note of any warning messages if they were there.  All I saw as the reset flashing.
When I had problems like this some time ago, I rec'd the following message from Art:
"Turn off the watchdog in config/general. If the CPU gets too bogged down
that error can occur, you may want to also turn off toolpath display if a
file is longer than 20 megs or so."
Anyway I keep the display on and turned the watchdog off.  So far I have done 2 similar items without a problem.
  •  9,374 9,374
Re: Sudden stop
« Reply #3 on: November 17, 2009, 02:00:30 AM »
I used to have a similar problem cutting lithophanes which have large files (320,000 or more lines of code) and found that the issue was related to a refresh of the LPT port. I never did discover if this was a Mach related or computer related thing but my cure was to reconfigure my limit switches and e-stop to 'push to make'. Not everybody will agree with this strategy but it worked for me.
