Mach Discussion => General Mach Discussion => Topic started by: rweatherly on November 14, 2009, 08:57:23 AM
I was machining a small detailed piece and the machining suddenly stopped. The file size is about 4 meg, with 320,000 lines of GCode.
I seem to remember something about the display being a problem, but I have been machining similar files without a stop.
Is there any way to find what makes Mach3 stop?
Are newer versions better? (I am running version R2.0.047)
Richard
It would be helpful if you could provide more details.
Was anything shown in the Status box after the stop ?
Was it an e-stop or limit switch triggered (Reset flashing) ?
Sorry for the delay in replying. I did not take note of any warning messages if they were there. All I saw as the reset flashing.
When I had problems like this some time ago, I rec'd the following message from Art:
"Turn off the watchdog in config/general. If the CPU gets too bogged down
that error can occur, you may want to also turn off toolpath display if a
file is longer than 20 megs or so."
Anyway I keep the display on and turned the watchdog off. So far I have done 2 similar items without a problem.
I used to have a similar problem cutting lithophanes which have large files (320,000 or more lines of code) and found that the issue was related to a refresh of the LPT port. I never did discover if this was a Mach related or computer related thing but my cure was to reconfigure my limit switches and e-stop to 'push to make'. Not everybody will agree with this strategy but it worked for me.
