Hello Guest it is October 20, 2026, 04:07:13 PM
Author Topic: Kirans Wizard  (Read 8670 times)
Offline Fastest1
  •  920 920
  • Houston, TX
Kirans Wizard
« on: October 23, 2009, 11:58:59 AM »
Last night after finding out my NFS wizards were unlicensed. I tried Kirans cicle cutting wizard. Everthing was going as planned (.250 2f.e.m., circle diameter 2.255, and .43 depth from Z0). I watched for many passes and then for no reason, machine was untouched, I had restarted mach fresh and only configured this wizard once for this hole/circle, and the cutter starts going across the inside of the circle (a previously uncut area). Is this normal? I checked my cv, it was on. It is abs in mode not inc. I noticed prior to this if I played with wizards a few times and loaded and removed gcodes without starting mach fresh, it seemed to have random  things happen, unexplained. This was all with air cuts. I thought I had associated it with not reopening mach fresh as that had corrected the cuts prior to this. Any ideas?
