Hello Guest it is November 22, 2026, 03:11:47 PM
Author Topic: Mach 3 ignoring Z setting  (Read 10711 times)
« on: October 05, 2009, 12:18:05 PM »
Hello all, relatively new to Mach 3 - when I first power the machine on and start the software up, I set X, Y, and Z settings before running a gcode. When I hit cycle start, the tool moves WAY up above the z I had set and does its thing in mid air. X and Y stay put where I set them but Z goes up a few inches. This only happens when I first use the machine in the morning. It happens every time; I just hit the spacebar, reset the Z and reload the gcode and it runs as it's supposed to.  What am I doing wrong here? RTFM I know, but the manual for Mach 3 puts me to sleep and doesn't really answer my queries in a language that I can get my head around. Aside from minor issues I've been having I'm starting to get better with it. thanks
Re: Mach 3 ignoring Z setting
« Reply #1 on: October 05, 2009, 03:55:44 PM »
Watch the videos then :)
Sounds like you are not understanding the offsets quite right.
« Reply #2 on: October 05, 2009, 05:15:53 PM »
Keep in mind that when you start Mach, tool zero is active, not tool 1,2,3, etc...
