Hello Guest it is November 22, 2026, 07:10:48 AM
Author Topic: Feedrate override for dummies? Please?  (Read 31860 times)
« on: October 02, 2009, 06:38:45 PM »
I have tried all kinds of methods to get a knob on the front of my panel to set feedrate manually. An arcade control (A-pac) with a pot is the only one I have gotten to work to date. I would like to just use an encoder/MPG to input through two parport inputs and do its thing. I got the encoder changing the MPG#1 DRO but that is as far as I have gotten. How do I get Mach to take this input and apply it to the feedrate? Simply. For dummies. Like me.
Re: Feedrate override for dummies? Please?
« Reply #1 on: October 03, 2009, 03:01:29 AM »
Just an ideia. If you have the keybord at and, you can assign a key to do feedrate+ and feedrate-. For example in my system, I use the 'S' key to start a cycle, so I belive that you can also do like this to feedrate+ and -.
I never did it, but I believe it works.
Filipe
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #2 on: October 03, 2009, 11:32:13 AM »
You could set up 2 OEMTriggers, 1 for the A channel and 1 for the B channel, then you have to write 2 macros 1 for each trigger to run, in the macros is a bit of code to increment or decrement the feed rate.
Graham
« Reply #3 on: October 04, 2009, 08:52:38 AM »
You guys give me WAY more credit than I deserve! Dummies are people who are intimidated by such terms as scancodes, hotkeys, keycodes, oem triggers, oemcode, modbus, triggers, macros, brains, etc. I am talking MAJOR dummy! Also, I am rather unlucky. If there is a bad plugin or a misprint in an instruction sheet, I am the one who will use it or follow it. I know, this really doesn't inspire confidence in anyone kind enough to assist me. However, I am persistent and appreciative! And dumb.
« Reply #4 on: October 04, 2009, 01:03:29 PM »
Just curious why you want to use an encoder rather than using a pot? To me a pot is the ideal thing to use and is what all the industrial machines use.
« Reply #5 on: October 04, 2009, 02:18:01 PM »
^^ and they're much cheaper ;)
« Reply #6 on: October 04, 2009, 03:29:17 PM »
Well, a pot requires some kind of A/D conversion to input it to Mach. Then what do you do with it? Encoders, contrary to popular belief, are cheaper than quality pots. A good Clarostat or Bourns costs me about $9.00. A CTS 2-bit encoder costs me $3.20 and no A/D conversion needed. If there is a simple way to do the A/D conversion like I was doing with that A-pac, a pot and Keygrabber, I am willing to try it. Keygrabber is one thing that works for me, most of the time. Also, does anyone know the keystroke for "reverse run"? There may not be one.
« Reply #7 on: October 04, 2009, 04:08:40 PM »
No keystroke set up for Reverse Run but you can easily add one of your choosing by editing the screen with screen4.
« Reply #8 on: October 04, 2009, 05:59:25 PM »
Yeah, Hood, I'll bet I could get a lot of stuff I want done if I would get used to changing things in Screen 4. I don't know why I don't just set aside the time to learn a bunch more of the options available. I am an old panel builder and I guess that makes me want to fix everything with another relay or a stacked switch. I can just barely program a simple PLC. Everything else I have tried with Mach, including the Galil plugin and J-code, has made sense and has worked for me. I tried EMC2 for a while but the lack of documentation frustrated me to no end. It ran a good, tight closed-loop with PWM output to DC servos. What more can you ask of a group with a penguin fetish? Do I put in a LOL now?
« Reply #9 on: October 04, 2009, 06:32:16 PM »
What I am not understanding is you said you had the pot working fine, so why change to an encoder.
I use the PoKeys on the mill to provide the analogue input and on the lathe and the new Mill I will be using analogue inputs on the PLC's. I just wrote a Brain to look at the input and it writes to the FRO  DRO.
