Hello Guest it is October 21, 2026, 03:28:45 AM
Author Topic: spindle rotation are reversed  (Read 15149 times)
« on: September 29, 2009, 10:46:46 AM »
Hello to all
My spindle is reversed when i input m03 it goes anticlockwise and m04 it turns clockwise.
How do i resolve this problem
Thank you for your time
Marcel
Re: spindle rotation are reversed
« Reply #1 on: September 29, 2009, 10:50:25 AM »
What type of spindle? How does it connect to Mach? Do you use M3/M4/M5 macros or is it just via the outputs on the spindle setup page?
« Reply #2 on: September 29, 2009, 11:16:00 AM »
Hello Hood
i think it goes via the output on the spindle setup page
« Reply #3 on: September 29, 2009, 12:25:56 PM »
Then sounds like you have the outputs set the wrong way round, just put whatever is set for M3 in the M4 box and M4 in the M3.
« Reply #4 on: September 29, 2009, 12:57:55 PM »
Hello Hood
How do i do that
Marcel
« Reply #5 on: September 29, 2009, 01:02:44 PM »
Go to Config menu then Ports and Pins then Spindle Setup and you will see the boxes for M3 and M4. If that doesnt change things then attach your xml and I will have a look to see how your spindle is set up.
« Reply #6 on: September 29, 2009, 01:08:38 PM »
Hello Hood
Problem resolved
Thank you for the advice and your time
Marcel
« Reply #7 on: September 29, 2009, 01:14:18 PM »
No problem :)
