Hello
Guest
it is
September 17, 2026, 09:39:09 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
spindle rotation are reversed
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: spindle rotation are reversed (Read 14928 times)
marcel beaudry
153
on:
September 29, 2009, 10:46:46 AM »
Hello to all
My spindle is reversed when i input m03 it goes anticlockwise and m04 it turns clockwise.
How do i resolve this problem
Thank you for your time
Marcel
Logged
Carnoustie, Scotland
Re: spindle rotation are reversed
Reply #1 on:
September 29, 2009, 10:50:25 AM »
What type of spindle? How does it connect to Mach? Do you use M3/M4/M5 macros or is it just via the outputs on the spindle setup page?
Logged
marcel beaudry
153
Reply #2 on:
September 29, 2009, 11:16:00 AM »
Hello Hood
i think it goes via the output on the spindle setup page
Logged
Reply #3 on:
September 29, 2009, 12:25:56 PM »
Then sounds like you have the outputs set the wrong way round, just put whatever is set for M3 in the M4 box and M4 in the M3.
Logged
marcel beaudry
153
Reply #4 on:
September 29, 2009, 12:57:55 PM »
Hello Hood
How do i do that
Marcel
Logged
Reply #5 on:
September 29, 2009, 01:02:44 PM »
Go to Config menu then Ports and Pins then Spindle Setup and you will see the boxes for M3 and M4. If that doesnt change things then attach your xml and I will have a look to see how your spindle is set up.
Logged
marcel beaudry
153
Reply #6 on:
September 29, 2009, 01:08:38 PM »
Hello Hood
Problem resolved
Thank you for the advice and your time
Marcel
Logged
Reply #7 on:
September 29, 2009, 01:14:18 PM »
No problem
Logged
Print
Pages:
1
Go Up
« previous
next »
