Hello Guest it is November 12, 2026, 02:36:32 AM
Author Topic: MachScreen releases  (Read 536369 times)
MachScreen releases
« on: September 21, 2009, 01:21:58 AM »
Hey all,
I've been asked to open a thread where users can see when a new version of MachScreen is released.
The actuell version is V1.27.0.
The brain isn't a soap, it doesn't shrink when used.
Re: MachScreen releases
« Reply #1 on: November 01, 2009, 09:33:02 AM »
Hey,
the new release V1.28 is available. New features and changes:
XML check ports / pins:  The text in the detailed errors field is now scrollable.
Shortcut key "Tab" / "Shift Tab" implemented to move to next / previous page.
When "Persit. data editable on all pages" was checked and you selected a persistent (hidden) object on page 50, the object frame was drawn, fixed.
EDIT:
download link:http://www.kd-dietz.de
Klaus
« Last Edit: November 01, 2009, 10:21:36 AM by Klaus1311 »
« Reply #2 on: November 01, 2009, 10:07:29 AM »
Can you put a link in this thread. :)
« Reply #3 on: November 01, 2009, 07:40:04 PM »
Thanks Klaus, your great.
« Reply #4 on: November 04, 2009, 08:21:20 AM »
Hey
Version V1.29 is available. Changes:
Size and position of the main window and property dialog is now stored with every file "save". If the checkbox "Remember windows positions" is set, the windows are placed on the stored position.
Bitmaps can now be loaded in the original size,when the checkbox "use org.size of bitmaps" is set.
Klaus
« Reply #5 on: November 08, 2009, 01:33:00 PM »
Hey,
Version V1.30 is available.
Changes:     "Image button" problem fixed. "Orig images" problem fixed.
Additional:
New checkbox "Show overlaying elements for selection". If set and a element is hit which is covered by other elements, a listview shows all elements for selection.
When more elements are selected with the rubberband, the master selection frame is flashing.
Klaus
« Reply #6 on: November 09, 2009, 08:07:32 AM »
Hey,
Version V1.31 is available.
Bug "overlaying elements" fixed.
The column width of the listview header is now remembered.
The background color outside of the design area is now selectable.
Klaus
« Reply #7 on: November 18, 2009, 12:22:09 PM »
Hey,
version 1.32.0 is available. Thanks to Jean-Baptiste all menu's and messages are translated into french and can now be selected. The french online help will be ready within the next few months. Some minor bugs are fixed and a few changes are done.
Klaus
« Reply #8 on: November 18, 2009, 04:26:19 PM »
Thanks Klaus.
« Reply #9 on: November 24, 2009, 05:08:01 AM »
Hey
version V1.33 is available. Changes:
1)  3 menu points added
"Add-on insert"  with this feature you can insert add-on / set-files in another set-file.
"Assign add-on pages" you have to assign every page from an add-on file to a not yet used page in your master set-file
"Save as add-on" you can save a new created screenset as an add-on file.
2)  when editing the filename in the "yellow edit-window" arrow-keys and the return key are now accepted.
Klaus
