Hello Guest it is November 12, 2026, 02:25:59 AM
Author Topic: MachScreen releases  (Read 536356 times)
Re: MachScreen releases
« Reply #70 on: November 08, 2011, 01:05:09 PM »
Hi Klaus,
is it possible to move objects with more than one step with the keyboard arrows? Like holding down "shift" to move it at a faster rate?
Jan Rune
« Reply #71 on: November 09, 2011, 03:15:10 AM »
Hi Jan,
you can move elements in different ways:
with the mouse by drag and drop
align elements horizontally and vertically to already positioned elements using the toolbar icons
by setting the position in the property dialog.
Placing elements with the arrow keys is for fine positioning. Setting the increment step I think wouldn't make it much more convenient.
Klaus
The brain isn't a soap, it doesn't shrink when used.
Offline Greolt
  •  956 956
« Reply #72 on: November 09, 2011, 04:02:37 AM »
Klaus
How about a way to constrain movement to either vertical or horizontal when dragging with the mouse. Perhaps a with hotkey.
I often find I want to move an object vertically but not lose horizontal position.  So I press the up arrow and wait for ages while the object crawls up the screen.  :D
Greg  (who loves MachScreen)
« Reply #73 on: November 09, 2011, 05:26:39 AM »
Thats the same issues im having. Sometimes i even loose the controls behind other controls as well. Thats why the shift command would be great. Its doable the way it is. But it could have been great :)
« Reply #74 on: November 09, 2011, 06:27:43 AM »
Hello
I've made version V1.53a width the following addition. Select your element and move it, while moving press the L key. Depending on the difference of start pos and the actual mouse pos, elements are only moved to either hor or vert direction, the greater diff wins.
Klaus
« Reply #75 on: November 09, 2011, 07:52:40 AM »
It is great, a bit more flexible moving of controls this way. I would appreciate if you would give the SHIFT+MOVE command another thought as well :) Anyways, thank you for Machscreen!
« Reply #76 on: January 05, 2012, 08:18:36 AM »
Hello MachScreen users!
A happy New Year to all of you.
MachScreen V1.54 is released and can be downloaded at http://www.kd-dietz.com/klausphp/index_eng.html
Fixes:
 If data where changed and a file from the MRU was opened the file to be opened was overwritten, fixed
Changes:
 made more robust against corrupted set files
 if Alt key is pressed at start-time of MachScreen a cmd string is ignored, and all windows are placed on the master screen
 Script length is controlled not to exceed 65535, if so, a warning message pops up
 DRO / Slider format can have now a trailing text also
 DRO format accepts now a %-sign
 Syntax coloring switched on again, was (forgotten) off for debugging purposes
 Attention!
 a feature implemented in version V1.53a has changed:
 Old
 Lock movement to hor / vert. The direction is determined by the actual mouse pos to the start mouse pos press L
 has changed
 New
 Toggle mouse movement orthogonal / random with icon. the direction is determined by the actual mouse pos to the start mouse pos toggle toolbar element right to selection toggle
 I did this change, because I think, it is more intuitive / easier to find / use an icon, than use a hidden key combination
Klaus
« Reply #77 on: January 05, 2012, 05:14:56 PM »
Happy New Year to you too Klaus!
Thanks for the update too.  You have certainly given us a nice tool.
« Reply #78 on: February 03, 2012, 05:24:15 AM »
Hello
I've released version V1.55. Changes and fixes:
Display order for image buttons changed
Initial values for toolpath changed
When view was changed to info view "file close" button was grayed, fixed
When a ctrl was deleted, overview view didn't show ctrl's behind deleted,fixed
Multi selection dialog can now also be used for changing display order with drag and drop functionality
Display order changes can be redone, when done with multi selection dialog
Last loaded file type is remembered and suggested on save as
Klaus
« Reply #79 on: March 07, 2012, 07:10:24 PM »
Hello Klaus.
Will it be possible to import the original Mach screen into your program and make hotkeys to all buttons? I tried this with Screen4 but not all of them worked. Will your program be a better choice for this purpose?
