Hello Guest it is November 12, 2026, 02:37:15 AM
Author Topic: MachScreen releases  (Read 536391 times)
Re: MachScreen releases
« Reply #60 on: May 21, 2011, 02:09:38 AM »
Hi Klaus,
We have just found with Hood that there is something that can be very useful which can be done in Screen4 but not in MachScreen. In Screen4 one can force leading zeros by using a formatting string something like this %04.0f. MachScreen on the other hand, doesn't output leading zeros with the same formatting string.
Also, using a formatting string like T%04.0f is allowed in Screen4 and and will output the T in front of the number. This is useful in some cases, like the one demonstrated by Hood, here:
http://www.machsupport.com/forum/index.php/topic,17093.msg127574.html#msg127574
Please consider adding these capabilities to MachScreen.
Thank you for your efforts and a great software!
« Reply #61 on: May 21, 2011, 02:18:20 AM »
Hi Dan,
I'll put this in the next version. Please give me some time to add it.
Klaus
The brain isn't a soap, it doesn't shrink when used.
« Reply #62 on: May 21, 2011, 02:26:05 AM »
Great!!
« Reply #63 on: May 25, 2011, 08:15:14 AM »
Hi Dan,
I've redone the DRO's format part of MachScreen. You can now set a preceding text, which is shown on DRO's and also set leading zeros.
Version V1.51 can be downloaded from my site.
Klaus
« Reply #64 on: May 25, 2011, 10:44:50 AM »
Thank you, Klaus!
« Reply #65 on: July 30, 2011, 07:55:00 AM »
Hello,
I've released MachScreen version V1.52.
Fixes and additions:
added: hor scrollbar to listbox fct
DRO's added
Current tool offset (lathe only) 245
Tool nmb and offset number"(lathe only), 246,
4th axis dia feed Mode, 187,
File new positioned window always on monitor 1 Pos0, now positioning to remembered pos
Editor Window: Not all codes where shown in the tip window
Editor Window: Tip window flickering fixed
Editor Window: Maximizing didn't work properly on secondary screen when sizes prim / sec were different, fixed
All missing image files are reported immediately after loading of set file showing filename and referencing page
Info "This function call is depreciated! Please use OEM / User instead" removed
function parameter is shown above cursor if would be outside of screen
Hotkey localized char issue fixed
Attr locked for selection wasn't saved, fixed
Klaus
Offline rcaffin
  •  1,073 1,073
« Reply #66 on: October 19, 2011, 05:09:43 PM »
Hi Klaus
I have just downloaded the latest version from your web site and installed it (twice).
Something seems to be wrong. The row of small buttons across the top above the active area is populated with mostly khaki buttons. There are about 3 with pictures on the buttons, that's all. After a while one button acquired a picture, but clearly something is wrong?
help please
Roger Caffin
« Reply #67 on: October 20, 2011, 04:57:13 AM »
Hi Roger
the toolbar icons you see in "khaki" are disabled. If you for example select an element, the icons cut, copy and delete should be enabled.
If you select at least 2 elements the align icons will be enabled.
Klaus
Offline rcaffin
  •  1,073 1,073
« Reply #68 on: October 20, 2011, 05:12:39 AM »
How ... bleeding obvious ... :-)
OK, thanks, back to work!
Roger
« Reply #69 on: November 01, 2011, 03:27:20 AM »
Hello
MachScreen V1.53 is ready for download. Fixes and additions:
In view "overview" you can make a selection of the printed columns
Print icon wasn't enabled in overview and hotkey view
Project export output issue fixed
Date / time values are build according to the locale OS settings of the computer
Function code for LE D's with number above 800 added
Klaus
