Hello Guest it is November 12, 2026, 02:37:01 AM
Author Topic: MachScreen releases  (Read 536385 times)
Re: MachScreen releases
« Reply #30 on: March 05, 2010, 03:08:40 PM »
Hello,
I made a small tutorial in form of a powerpoint presentation, nothing much. I will wait for opinion, if this could be a way as a video substitution.
Please tell me what you think about it.
Klaus
The brain isn't a soap, it doesn't shrink when used.
« Reply #31 on: March 14, 2010, 03:49:54 AM »
Hi
version V1.40 is available. Changes:
MRU issue fixed.
Right and bottom members of position group in property dialog are no more editable
Multiple instances can now be run at the same time. If the same set-file is opened in different instances, only the first opened file has read-write permission. This means, changes in any file other the "first" opened cannot be saved. Although there can be more than one instance running, there is no way of copying from one instance to another.
EDIT: When window was scrolled, positions of selected items were calculated wrong.
Klaus
« Last Edit: March 14, 2010, 06:21:06 AM by Klaus1311 »
« Reply #32 on: April 24, 2010, 07:13:17 AM »
version V1.41 is available.
Added:
The integrated editor supports now Cypress basic syntax coloring. Additional to that it supports Mach functions as well. When a Mach function is recognized, the available parameters are shown in a listbox. Clicking the required parameter inserts this parameter into the function.
This was a lot of writing and I did a lot of testing. If you find a misspelling or a reserved word which is not recognized. Please feel free to tell me.
Klaus
« Reply #33 on: April 24, 2010, 09:22:00 AM »
Wow............  and, Double Wow.......... two thumbs waaaaayyyyyy up!!!!!!!!
You are one amazing dude.
scott
« Reply #34 on: April 24, 2010, 11:59:37 AM »
Machscreen is unbeatable. Thanks again Klaus.
Zafar
« Reply #35 on: April 24, 2010, 02:41:24 PM »
Klaus,
Appreciate the work you put into the screen deisgner for making it easy.
Even i may get dangerous and start fooling with screen designs.
« Reply #36 on: May 20, 2010, 02:11:51 PM »
Hello
version V1.42 is available.
Additions: toolbar for editor, GCode syntax coloring, editor un- and redo possibility, data printable.
Klaus
« Reply #37 on: May 21, 2010, 06:40:37 AM »
It keeps getting better and better. Thanks Klaus.
Zafar
« Reply #38 on: June 01, 2010, 12:16:01 PM »
Hi Klaus,
Thank you very much for a great Mach screen editing software! Have never had the courage to design a screen using Screen4. MachScreen looks very simple and friendly.
Daniel
« Reply #39 on: June 14, 2010, 06:55:28 AM »
I just grabbed 1.43 and whenever it starts up there's a messahe: "MachScreenReadOnly.dll not found"
After acknowledging the error, MachScreen seems to run OK. Should I revert to an earlier version or is this OK?
