Hello Guest it is November 24, 2026, 05:02:43 AM
Author Topic: 1st MDF  (Read 53071 times)
Offline kolias
  •  1,165 1,165
1st MDF
« on: September 02, 2009, 08:42:01 AM »
This is my 1st attempt to use my CNC router to cut a piece of MDF (MDF is something like pressboard but very smooth on both sides)
I’m attaching the DXF and LCAM files here and have set the parameters to the best I can. I will be using a 1/8” upcut straight bit.
Can anyone comment on my settings?  Did I miss something?
Nicolas
Nicolas
Re: 1st MDF
« Reply #1 on: September 02, 2009, 10:15:10 AM »
If you set Z=0 to the top of your workpiece, it won't cut anything. All your cuts are at Z=0
Offline kolias
  •  1,165 1,165
Re: 1st MDF
« Reply #2 on: September 02, 2009, 01:47:42 PM »
I changed in LC (Layers), the Cut Depth value to -0.1250 and regenerated the gcode. Is this my problem?
Nicolas
Nicolas
Offline kolias
  •  1,165 1,165
Re: 1st MDF
« Reply #3 on: September 02, 2009, 03:49:43 PM »
Sorry, I also changed the Entities
Revised files attached
Nicolas
Nicolas
Re: 1st MDF
« Reply #4 on: September 02, 2009, 05:50:28 PM »
Try it using 0.125, NOT -0.125.
 I think LazyCAM wants a positive number for depth of cut, as it's now cutting .125 above the part.
Re: 1st MDF
« Reply #5 on: September 02, 2009, 05:57:49 PM »
Actually you want it to look like this for the depth in the picture below. Note: I only fooled with the depth so don't look at anything else as an example!  ;)
Offline kolias
  •  1,165 1,165
Re: 1st MDF
« Reply #6 on: September 02, 2009, 06:39:08 PM »
The manual says this number should be negative, unless I dont understand something
Nicolas
Nicolas
Re: 1st MDF
« Reply #7 on: September 02, 2009, 07:25:48 PM »
A slice of foam insulation board is good instead of MDF for trial runs, it cuts cleanly and you can't snap a cutter in it even if you rapid through it with no spindle on ;)
Re: 1st MDF
« Reply #8 on: September 02, 2009, 07:48:31 PM »
I don't use lazyCCAM, but the code you posted is cutting at Z 0.125.
Nicolas
Offline kolias
  •  1,165 1,165
Re: 1st MDF
« Reply #9 on: September 02, 2009, 09:58:50 PM »
Sorry Gerry, my mistake
I will correct it
Nicolas
Nicolas
