Hello Guest it is November 22, 2026, 08:13:02 AM
Author Topic: Mach3  (Read 11737 times)
Offline Ray
  •  70 70
Mach3
« on: August 30, 2009, 08:23:20 PM »
I just downloaded Mach3 off the website onto a desktop computer with XP and 512 Memory.  Every tap file I run  shows up on the display as a dot in the middle of the display and you can not see the movement as the gcode cycles.  Did I do something wrong?  ray
Re: Mach3
« Reply #1 on: August 30, 2009, 08:42:10 PM »
Ray,
Just zoom in - Shift-Drag up and down with the mouse to zoom.
Offline Ray
  •  70 70
Re: Mach3
« Reply #2 on: August 30, 2009, 08:50:24 PM »
Thanks Ray L.  I will do that.  This version has LazyCam as a seperate installation.  The one I have on my laptop in the shop (also XP) must be an earlier version. (I haven't looked yet).  Ray
Re: Mach3
« Reply #3 on: August 31, 2009, 06:16:41 PM »
Also make sure you've enables the axes and set up your motor tuning to some realistic (if imaginary) values, or it may not play. Had this problem on a laptop recently that I was using for simulation only.
