Hello Guest it is November 22, 2026, 07:53:05 PM
Author Topic: Where is the Driver Test Utility located?  (Read 10722 times)
Offline Jim
  •  16 16
« on: August 26, 2006, 05:07:43 PM »
Where is the Driver Test Utility located? I've looked around the FTP site, with no luck. I've installed Mach3 and am trying to go through the tuning process. I'm having a problem with the Taig CNC Z axis. A rapid up, fails 2 out of 3 times. I call for 1" move, and the head raises about an 1/8th inch then buzzes. Of course the following downward movement wants to bury the tool into the stock.
Jim
Re: Where is the Driver Test Utility located?
« Reply #1 on: August 26, 2006, 05:11:39 PM »
In the main Mach3 directory on your hard drive.  Assuming of course you are using Mach3.
Offline Jim
  •  16 16
« Reply #2 on: August 26, 2006, 05:15:52 PM »
Doh!
