Hello Guest it is November 22, 2026, 06:04:48 PM
Author Topic: Mach3 turn newbie questions:  (Read 10513 times)
« on: August 02, 2009, 04:29:22 PM »
Ok I'm a complete newbie to CNC turning and I have some questions before I spend money.  I have done some reading and some things I do understand, while some things I don't.
In Mach3 turn I understand about the tool X and Z offsets for tool changes and wear offsets, but what I don't understand is how to position the toolpost for a tool change.  Say I'm turning a part (55 degree insert) that is 1" long by .75" diameter and want to switch to a cutoff tool, and minimize the distance the cross slide travels to make the tool change. I will not be using limit switches.
Most of my work would be done without the tailstock, but eventually I will try turning between centers.
If someone can shed some light on things in a simple format, I would appreciate it.  I often suffer from migraine headaches, so things take a while to sink in sometimes.
Michael
Re: Mach3 turn newbie questions:
« Reply #1 on: August 02, 2009, 05:10:47 PM »
Best way probably is just to have your code move to a position that is suitable for the setup you have at that time. Lathes are hard to do changes to compared to a mill as there are so many things that can get in the way if you define a single position for a toolchange or certainly is on mine with front and rear toolposts with boring bars sticking out etc etc.
