Hello
Guest
it is
October 16, 2026, 01:20:38 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Using USB connections
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Using USB connections (Read 9708 times)
widpyro
91
on:
August 25, 2006, 07:01:50 PM »
I want to go from a USB output to a DB9 connector. Should I assign the outputs on pins 1-9?
-jim
www.ctpyro.com
Brian Barker
3,860
Re: Using USB connections
Reply #1 on:
August 25, 2006, 07:27:46 PM »
You can't do that
if you need more IO you will need to get a 2nd printer port
sorry
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
Print
Pages:
1
Go Up
« previous
next »
