Hello Guest it is November 22, 2026, 08:18:55 PM
Author Topic: Using USB connections  (Read 9973 times)
« on: August 25, 2006, 07:01:50 PM »
I want to go from a USB output to a DB9 connector. Should I assign the outputs on pins 1-9?
-jim
www.ctpyro.com
Re: Using USB connections
« Reply #1 on: August 25, 2006, 07:27:46 PM »
You can't do that :( if you need more IO you will need to get a 2nd printer port
sorry
www.newfangledsolutions.com
www.machsupport.com
