Hello Guest it is October 15, 2026, 10:30:57 PM
Author Topic: DynaTorch THC  (Read 14396 times)
DynaTorch THC
« on: August 25, 2006, 12:30:27 AM »
Hello,
Has anyone heard or used the DynaTorch torch height control with Mach 3? Does it work? How does it compare to campbells TCH 300?
here is the link:
http://www.dynatorch.com/avhtctrl.htm
Regards
Fernando
Re: DynaTorch THC
« Reply #1 on: August 25, 2006, 10:44:25 AM »
That one is not going to hook into mach3.. other then that it should work???
www.newfangledsolutions.com
www.machsupport.com
Re: DynaTorch THC
« Reply #2 on: August 25, 2006, 11:05:27 AM »
Any recomendations on Torch height control attachments?
I am a little bit sceptical and uninformed  about the floating head design needed to use campbells THC.
Regards
Fernando
Re: DynaTorch THC
« Reply #3 on: August 25, 2006, 11:18:14 AM »
did you look a the one from C&Cnc ...
www.machsupport.com
Re: DynaTorch THC
« Reply #4 on: August 25, 2006, 11:23:47 AM »
Hi Brian,
Yes I did, it has more bells and whistles than the one from bob campbell, but it uses the same principle of the floating head. I still dont know entirely how that works.
Will look into it
Fernando
