Hello Guest it is November 13, 2026, 01:05:32 PM
Author Topic: Memory leak win2000 mach3 v3.041  (Read 50474 times)
Re: Memory leak win2000 mach3 v3.041
« Reply #10 on: July 03, 2009, 03:06:14 AM »
thanks TP
« Reply #11 on: July 03, 2009, 01:31:01 PM »
sorry never got a chance to try today, have been working away from the workshop all day.
vmax549
« Reply #12 on: July 03, 2009, 03:57:35 PM »
I wathed the MEM all day today running many file some hrs long.
Nothing unusaul, MEM usage went up AND down depending on the program but I ended at about the same as I started with all day long.
NOW this IS running the dual cpu driver NOT the single that you may be running .
« Reply #13 on: July 03, 2009, 04:18:46 PM »
The memory leak is pretty severe, 150mb in 25 minutes, it doesn't take long for things to slow down.
Sven
« Reply #14 on: July 05, 2009, 05:49:09 AM »
Have had Mach running on the laptop for 24hrs now and no memory leak at all for me. The laptop have svce pack 3.
« Reply #15 on: July 05, 2009, 03:58:26 PM »
thanks Hood
Sven
« Reply #16 on: July 05, 2009, 09:14:30 PM »
I have updated to 3.042.020 with no improvement,
 Also ran Mach3 lathe and plasma without g100 to see what happens  and I get the same severe memory leak ???.
Started every program on the pc to check if there was any other leaks, seems its only mach.
The pic shows the pc inside the control cabinet, this is why I dont want to update it.
Sven
« Reply #17 on: July 06, 2009, 04:35:27 PM »
as an experiment could you delete the pulsing engine from Device manager and see if the memory leak still happens? Obviously you wont be able to use the machine when you do that.
« Reply #18 on: July 06, 2009, 07:37:42 PM »
that sounds a bit tricky for my pc skills, how is this done?
Sven
« Reply #19 on: July 07, 2009, 12:33:00 AM »
Go to Start button then control panel then System then Hardware then device manager. Look for the pulse engine, right click and delete.
 To reinstall just go to Mach3 folder and run the DriveTest.exe. but try Mach first before you reinstall it to see if you get the memory leak.
